Is it working on Windows? Which version are you using, 1.14? I believe that there might have been a problem opening ResultsViewer from the run tab on Mac. I think it did work if you launched ResultsViewer separately and browsed to the sql file. I also think @kyle fixed this for the 2.1.0 release.
![]() | 2 | No.2 Revision |
Is it working on Windows? Which version are you using, 1.14? I believe that there might have been a problem opening ResultsViewer from the run tab on Mac. I think it did work if you launched ResultsViewer separately and browsed to the sql file. I also think @kyle benne fixed this for the 2.1.0 release.
