Yes. EnergyPlus calculates the Yesbarometric pressure based on elevation. Density of air within the air systems is calculated based on pressure.
Yes. EnergyPlus calculates the outdoor barometric pressure based on elevation. Density of air within the air systems is calculated based on outdoor barometric pressure.
| 4 | No.4 Revision |
