The heat pump model in EnergyPlus is actually 2 coil models that represent the single coil in a typical heat pump. One coil models the cooling performance, the DX cooling coil, and the other models the reverse cycle for heating, the DX heating coil. These models are found in the source code in DXCoils.cc. The CalcDoe2DXCoil function models the cooling coil while the CalcDXHeatingCoil models the heating coil. Only one of these coils is active at any given time. The documentation and equations for each are found in the Engineering Reference document under Single-Speed Electric DX Air Cooling Coil and Single-Speed Electric Heat Pump DX Air Heating Coil.
Answers to your questions:
