I did something similar some time back to fix the VAV size. I don't know if there is an easier way to do it. You can find the designed or sized outputs in .eio file that is generated after the first simulation. From this .eio file look for the right table for the right sized variable. Replace the autosize variable in .idf file with the designed value from the .eio file from the earlier simulation.
