I'm not aware of a measure on the BCL that does this. There is a method called removeEquipment in the OSlib_HVAC.rb module that's included in the /resources folder of some BCL measures, e.g. the AEDG measures.
If you're using the API outside of formal measures the code below will remove all HVAC systems. If you'd like a formal measure to do this, I've created a one and committed it to the UnmetHours OpenStudio Measures GitHub repository.
# get model objects
air_loops = model.getAirLoopHVACs
plant_loops = model.getPlantLoops
zones = model.getThermalZones
# do stuff
plant_loops.each do |plant_loop|
plant_loop.remove
end
air_loops.each do |air_loop|
air_loop.remove
end
zones.each do |zone|
zone.equipment.each do |zone_equipment|
zone_equipment.remove
end
end
