If you would like a quick way to generate windroses from a .epw files, check out epwvis, a web-based visualizing/analyzing tool for weather files. It is open source (MIT License). The specific javascript code for generating the windrose is on github with a d3.js dependency.
You can also generate windroses with ladybug, which is also open source. Python code here.
There are other free but closed source tools for generating windroses listed here.
If you would like a quick way to generate windroses from a .epw files, check out epwvis, a web-based visualizing/analyzing tool for weather files. You can drag-drop an .epw file onto the page to generate a windrose. It is open source (MIT License). The specific javascript code for generating the windrose is on github with a d3.js dependency.
Example epwvis windrose:
| 4 | No.4 Revision |
