Hi @willisrile, just to be clear, are you trying to use the E+ object MaterialProperty:GlazingSpectralData? That object is not yet wrapped in OpenStudio, therefore @MJWitte is correct. The best way to handle this right now is to write an EnergyPlus Measure that will import the MaterialProperty:GlazingSpectralData and then reference that data from your glazing materials. You can then add this measure to your OpenStudio model and it will be applied at runtime before the E+ simulation starts.
