IIUC, you want a table with two columns: Space Name, and Space Type Name.
As @adhilton mentioned, space.spaceType returns an optional SpaceType, so you need to check if it's empty or not, and if not do space.spaceType.get that will return a SpaceType, and then get it's name and convert to a string. Chained together: space.spaceType.get.name.to_s
You should really do this in one loop for efficiency (and because there's no reason to do it in two...).
space_hash = []
model.getSpaces.each do |space|
if space.spaceType.empty?
space_type = space.spaceType.get.name.to_s
else
space_type = "No Space Type Defined"
end
space_hash << {:space => space.name.to_s, :space_type => space_type}
end
require 'csv'
space_hash = []
else
end
end
Then you can export to a csv:
# Export to a csv file
CSV.open("space_spacetypes.csv", "wb") do |csv|
csv << space_hash.first.keys # adds the attributes name on the first line
space_hash.each do |hash|
csv << hash.values
end
end
As @adhilton mentioned, space.spaceType returns an optional SpaceType, so you need to check if it's empty or not, and if not do space.spaceType.get that will return a SpaceType, and then get it's name and call .name which returns an optional string so convert to a string. that to a string using .to_s. Chained together: space.spaceType.get.name.to_s
require 'csv'
space_hash = []
else
end
end
csv << hash.values
end
end
| 4 | No.4 Revision |
As @adhilton mentioned, space.spaceType returns an optional SpaceType, so you need to check if it's empty or not, and if not do space.spaceType.get that will return a SpaceType, and then call .name which returns an optional string so convert that to a string using .to_s. Chained together: space.spaceType.get.name.to_s
You should really do this in one loop for efficiency (and because there's no reason to do it in two...).two...). I like to store such tables in an array of hashes, as it is very convenient to work with in Ruby if you need to some more processing, and really easy to export to a CSV file using the standard bit of code I'm posting here.
require 'csv'
space_hash = []
else
end
end
csv << hash.values
end
end
| 5 | No.5 Revision |
As @adhilton mentioned, space.spaceType returns an optional SpaceType, SpaceType, so you need to check if it's empty or not, and if not do space.spaceType.get space.spaceType.get that will return a SpaceType, an actual SpaceType, and then call .name which returns an optional string so convert that to a string using .to_s. Chained together: space.spaceType.get.name.to_s
You should really do this in one loop for efficiency (and because there's no reason to do it in two...). I like to store such tables in an array of hashes, as it is very convenient to work with in Ruby if you need to some more processing, and really easy to export to a CSV file using the standard bit of code I'm posting here.
require 'csv'
space_hash = []
else
end
end
csv << hash.values
end
end
| 6 | No.6 Revision |
As @adhilton mentioned, space.spaceType returns an optional SpaceType, so you need to check if it's empty or not, and if not do space.spaceType.get that will return an actual SpaceType, and then call .name which returns an optional string so convert that to a string using .to_s. Chained together: space.spaceType.get.name.to_s
require 'csv'
space_hash = []
else
else
end
end
csv << hash.values
end
end
