Hi,
You should look at these things:
1) Make sure that your OpenStudio model is made in a New Space.
2) Verify that you chose the render type as Render objects by surface type. The color that appear depends on surface type.
3) You can go in OpenStudio Inspector and click on a surface. It will show you which type of surface it is. Even if you change the color of the surface, you will be able to look which surface type it is.
I hope it was helpful,
