First, you'll have to get the ID of the row that contains this window construction.
For this example, assume that the name of the window construction in the IDF is Window Cons A
Note the window construction name must be all uppercase in the query, even if not uppercase in the IDF.
 row_id = "SELECT RowName
              FROM tabulardatawithstrings
              WHERE ReportName='EnvelopeSummary'
              AND ReportForString='Entire Facility'
              AND TableName='Exterior Fenestration'
              AND Value='WINDOW CONS A'"
Next, get the SHGC using the row ID
  shgc = "SELECT Value
              AND ColumnName='Glass SHGC'
              AND RowName=row_id"
You can replace Glass SHGC with Glass Visible Transmittance or Glass U-Factor in the second query to get these other properties too.
