1 | initial version |
LowTempRadiant:VariableFlow
doesn't listen to external thermostat controllers. You set the type of control you want in the Temperature Control Type
field (in your case you probably want to set this to MeanAirTemperature
and then you define your heating and cooling schedules in the Heating Control Temperature Schedule Name
and Cooling Control Temperature Schedule Name
2 | No.2 Revision |
Check out the Input/Output Reference; explains it pretty clearly.
