There's a measure for that called Create DOE Prototype Building measure. Importing the IDF directly to OpenStudio will retain everything except the HVAC system.
There's a measure for that called Create DOE Prototype Building measureBuilding. I just tested the measure and it works for 1.14.0 but not 2.0.2. Importing the an IDF directly to OpenStudio will retain translate everything except the HVAC system. system.
There's a measure for that called Create DOE Prototype Building. I just tested the measure and it works for 1.14.0 but not 2.0.2. Importing an IDF directly to OpenStudio will translate everything except the HVAC system.
