1 | initial version |
Thanks for pointing this out. We updated its last week, but I can confirm what you see. I'll try to fix it tonight, if I can't then I'll email you a working copy.
2 | No.2 Revision |
Update: @m.vesely I revered to an older version on BCL, that has package contents, I'll re-upload most current version when I can address the issue with package contents. You should see the files below now when you go to the link and when you download the measure.
3 | No.3 Revision |
Update:
measure.
