Hi David, yes the model runs.
I believe the answer might have been covered elsewhere. The Sketchup GUI corrupts OS Measures. After running a model with added OS Measures you cannot alter anything with the Sketchup GUI or the .osm becomes corrupt and PAT will likewise fail.
Best Regards,
Matt
Hi David, yes
The reason the model runs. reports "disappeared" was because the
I believe answer might specified year does not stick sometime. It could have been covered elsewhere. The Sketchup GUI corrupts OS Measures. After running a model with added OS Measures you cannot alter anything with the Sketchup GUI or the .osm becomes corrupt and PAT will likewise fail. result of "save as". Best Regards,
MattThank you,
Matt
