We have not yet moved OpenStudio to Visual Studio 2015 although there is interest in that. At the current time I would suggest using Visual Studio Community 2013. You will need to set the PreferredToolArchitecture environment variable to x64 as noted here. This tells Visual Studio to use the 64 bit version of link.exe which is required when building some of the larger modules.
