1 | initial version |
Thanks Archmage, I tried both of your suggestions,
there is only one baseboard on the pump loop. When i keep the pump flow rate fixed, It caps the flow rate on baseboard to that value but it still fluctuates between 0 and that value. Even if i try to keep the thermostat value pretty high (like 50 c), that results in severe errors with crazy high temperature points.
I put a loadprofile:plant after the baseboard with zero load but controlling that object flow rate can not overwrite the base board flow rate.
Do you think if i change from a zone equipment like baseboard to a heating coil which is controlled by a setpoint manager connected to the thermal zone, Would there be any chance that i can control its mass flow rate?
2 | No.2 Revision |
there is only one baseboard on the pump loop. When i keep the pump flow rate fixed, It caps the flow rate on baseboard to that value The first suggestion works but it still fluctuates between 0 and that value. Even if i try is required to keep the thermostat value pretty high (like 50 c), that results in severe errors with crazy to a high temperature points.and remove the bypass pipe.
