Thanks for the Advise, everyone. I found the main problem: Ventilation values for sizing and simulation were different. I guess the temperatures being correctly in the sizing periods was just "luck".
Now, I see that the unmethours is still high... That, I assume, is because the Design Days are not the "actual peaks".
THANKS
