After I wrote all this I realized it would be more efficient and scalable to go backward though the mixer rather than forward through the splitter. Oh well.
def airLoopThermalZones(workspace, runner, air_loop, zone_names)
air_loop_name = air_loop.getString(0).get.to_s
# splitters
splitters = workspace.getObjectsByType("AirLoopHVAC:ZoneSplitter".to_IddObjectType)
# terminals
uncontrolleds = workspace.getObjectsByType("AirTerminal:SingleDuct:Uncontrolled".to_IddObjectType)
cv_reheats = workspace.getObjectsByType("AirTerminal:SingleDuct:ConstantVolume:Reheat".to_IddObjectType)
vav_reheats = workspace.getObjectsByType("AirTerminal:SingleDuct:VAV:Reheat".to_IddObjectType)
vav_noreheats = workspace.getObjectsByType("AirTerminal:SingleDuct:VAV:NoReheat".to_IddObjectType)
piu_series_reheats = workspace.getObjectsByType("AirTerminal:SingleDuct:SeriesPIU:Reheat".to_IddObjectType)
piu_parallel_reheats = workspace.getObjectsByType("AirTerminal:SingleDuct:ParallelPIU:Reheat".to_IddObjectType)
# adus
adus = workspace.getObjectsByType("ZoneHVAC:AirDistributionUnit".to_IddObjectType)
# equipment lists
equip_lists = workspace.getObjectsByType("ZoneHVAC:EquipmentList".to_IddObjectType)
# equipment connections
equip_connections = workspace.getObjectsByType("ZoneHVAC:EquipmentConnections".to_IddObjectType)
# required intermediate arrays
air_terminal_names = []
adu_names = []
equip_list_names = []
# get air loop inlet node list
inlet_nodelist_name = air_loop.getString(8).get.to_s
inlet_nodelist = workspace.getObjectByTypeAndName("NodeList".to_IddObjectType, inlet_nodelist_name).get
# get air loop demand inlet node name
node_name = inlet_nodelist.getString(1).get.to_s
# find cooresponding splitter
splitter = nil
splitters.each do |splitter_temp|
if splitter_temp.getString(1).get.to_s == node_name
splitter = splitter_temp
end
end
# store all splitter outlet node names
splitter_outlet_node_names = []
for i in 2..splitter.numFields.to_i-1
splitter_outlet_node_names << splitter.getString(i).get.to_s
end
# find terminals that use stored splitter outlet nodes
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, uncontrolleds, 2, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, cv_reheats, 3, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, vav_reheats, 3, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, vav_noreheats, 3, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, piu_series_reheats, 5, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, piu_parallel_reheats, 6, runner)
if splitter_outlet_node_names.size >= 1
runner.registerError("There were #{splitter_outlet_node_names.size} that were not able to be matched to terminals for #{air_loop_name}.")
return false
end
adus.each do |adu|
adu_terminal_name = adu.getString(3).get.to_s
air_terminal_names.each do |air_terminal_name|
if air_terminal_name == adu_terminal_name
adu_names << adu.getString(0).get.to_s
end
end
end
if adu_names.size == 0
runner.registerError("No ADUs were able to be matched to air terminal names for #{air_loop_name}.")
return false
end
equip_lists.each do |equip_list|
i = 2
length = equip_list.numFields.to_i
while i < length
equip_list_adu_name = equip_list.getString(i).get.to_s
adu_names.each do |adu_name|
if adu_name == equip_list_adu_name
equip_list_names << equip_list.getString(0).get.to_s
end
end
i = i + 4
end
end
if equip_list_names.size == 0
runner.registerError("No equipment lists were able to be matched to air distribution units for #{air_loop_name}.")
return false
end
equip_connections.each do |equip_connection|
equip_connection_equip_list_name= equip_connection.getString(1).get.to_s
equip_list_names.each do |equip_list_name|
runner.registerInfo("Checked #{equip_list_name} with #{equip_connection_equip_list_name}")
if equip_list_name == equip_connection_equip_list_name
zone_names << equip_connection.getString(0).get.to_s
end
end
end
if zone_names.size == 0
runner.registerError("No zones were able to be matched to air loops for #{air_loop_name}.")
return false
end
return zone_names
end
# splitters
# terminals
vav_hc_noreheats = workspace.getObjectsByType("AirTerminal:SingleDuct:VAV:HeatAndCool:NoReheat".to_IddObjectType)
# adus
# equipment lists
air_terminal_names adu_terminal_names = []
other_terminal_names = []
adu_names = []
splitter = nil
end
end
end
end
end
end
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, other_terminal_names, uncontrolleds, 2, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, adu_terminal_names, cv_reheats, 3, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, adu_terminal_names, vav_reheats, 3, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, adu_terminal_names, vav_noreheats, 3, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, adu_terminal_names, vav_hc_noreheats, 3, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, piu_series_reheats, 5, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, air_terminal_names, adu_terminal_names, piu_parallel_reheats, 6, runner)
return false
end
end
adus.each do |adu|
air_terminal_names.each adu_terminal_names.each do |air_terminal_name|
end
end
end
end
end
end
i = 2
while i < length
if adu_names.size > 0
end
end
elsif other_terminal_names.size > 0
other_terminal_names.each do |other_terminal_name|
if other_terminal_name == equip_list_adu_name
end
end
else
runner.registerError("No ADUs were equipment able to be matched to air terminal names for #{air_loop_name}.")
return false
end
i = 2
while i < length
end
end
end
i = i + 4
end
end
return false
end
end
end
end
return false
end
return zone_names
end
def checkTerminalNodeMatch(splitter_nodes, air_terminal_names, terminals, field, runner)
if splitter_nodes.size >= 1
splitter_nodes.each do |splitter_node|
# for uncontrolled terminals
terminals.each do |terminal|
if terminal.getString(field).to_s == splitter_node
air_terminal_names << terminal.getString(0).get.to_s
splitter_nodes -= [splitter_node]
runner.registerInfo("Found Match! Terminals Matched: #{air_terminal_names.size}, Splitter Nodes Left: #{splitter_nodes.size}.")
break
end
end
end
end
return splitter_nodes
end
# splitters
# terminals
# adus
# equipment lists
adu_names = []
splitter = nil
end
end
end
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, other_terminal_names, uncontrolleds, 2, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, cv_reheats, 3, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, vav_reheats, 3, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, vav_noreheats, 3, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, vav_hc_noreheats, 3, runner)
splitter_outlet_node_names = checkTerminalNodeMatch(splitter_outlet_node_names, adu_terminal_names, piu_parallel_reheats, 6, runner)
return false
end
adus.each do |adu|
end
end
end
i = 2
while i < length
end
end
end
end
else
runner.registerError("No equipment able to be matched to air terminal names for #{air_loop_name}.")
return false
end
i = i + 4
end
end
return false
end
end
end
end
end
end
end
return false
end
end
return zone_names
end
end
#NESTED IFS END LIVES
break
end
end
end
end
end
end
end
end
end
