You could also add (replace) Output command in your in.idf file.
OutputControl:Table:Style, Comma, ! Column Separator InchPound; ! Unit Conversion
Run the model as usual then look in the folder ModelToIdf for the in.idf. This is what gets sent to Energy Plus. Just add the above and you will get results cfm, kBtu, ft3, kWh. Give your in.idf file a new name and you can always look at tables in both units. Matt
