There is an option in EP-Launch, I believe disabled by default, to allow more than 250 columns. In reality, it's actually 255 variables + one row header that gives 256 columns. So by default the CSV output generated by ReadVarsESO has maximum 256 columns.
This is due to the - now completely outdated - inner limitations of Excel. Indeed, before Excel 2007, you could only have 256 columns.
| | Max. Rows | Max. Columns |
| Excel 365* | 1,048,576 | 16,384 |
| Excel 2013 | 1,048,576 | 16,384 |
| Excel 2010 | 1,048,576 | 16,384 |
| Excel 2007 | 1,048,576 | 16,384 |
| Excel 2003 | 65,536 | 256 |
| Excel 2002 (XP) | 65,536 | 256 |
| Excel 2000 | 65,536 | 256 |
| Excel 97 | 65,536 | 256 |
| Excel 95 | 16,384 | 256 |
| Excel 5 | 16,384 | 256 |
(Source of table: superuser)
In EP-Launch, Go the options, and find "Allow More Than 250 Columns" and check the box (I believe it sits under "Miscellaneous" according to the source code).
Side notes:
There is an option in EP-Launch, I believe disabled by default, to allow more than 250 columns. In reality, it's actually 255 variables + one row column header that gives 256 columns. So by default the CSV output generated by ReadVarsESO has maximum 256 columns.
Side notes:
