1 | initial version |
If you look towards the bottom of the Activity tab in DesignBuilder you'll see there are inputs for "Process" (and other non-standard) gains. See the Help information here: http://www.designbuilder.co.uk/helpv5.0/#_Process_gains.htm
I'm not sufficiently well versed with LEED requirements to answer your questions on that. A useful starting point might be the DesignBuilder v5 ASHRAE 90.1 modelling guide which can be downloaded via the link on the Help page here: http://www.designbuilder.co.uk/helpv5.0/#ASHRAE90.1Modelling.htm?Highlight=ashrae 90.1 or just search the v5 online Help file via the Help option in the interface using the term ASHRAE 90.1.
