click to hide/show revision 1
initial version
I could be wrong (fell free to slam that downvote button), but for choice values I believe you only want to fill out the 'default value' and 'enumerations' field. The other fields you filled out there don't apply (Min, Max, Mean, Standard Deviation, Discrete Values, Distribution).
Example...
If it were me, I'd use a measure that just alters the U-Value, SHGC and VT of a particular construction. That way you can us a double type variable and continuously run through a range of possibilities.
click to hide/show revision 2
No.2 Revision
NOT A CORRECT ANSWER. Keeping as answer to maintain integrity of comments below.
Example...
