You found the oldest, and likely least-useful, set of articles. To date, there have been 4 primary-source articles which have spawned 30+ in the news:
For a partial listing of Autotune news buzz, see bit.ly/autotune_publicity.
While any multi-objective search algorithm can provide an answer, the DOE/BTO-funded Autotune project conducted an extensive search of over 300,000 algorithm instances to quantify performance of the best calibration algorithm in terms of:
The research, detailed in over 30 peer-reviewed publications (bit.ly/autotune_science), has been completed and Autotune is now open-source on GitHub (bit.ly/autotune_code) for use by the private sector.
Regarding practical use of Autotune, there are a few resources that might help:
Step-by-step instructions for 3 ways to run Autotune (easiest to hardest/most-flexible):
1) Standalone demo - download the directory, replace myidf.idf, myparams.csv, myuserdata.csv, and myweather.epw with your own files, and double-click autotune.bat.
2) Virtual machine - download a virtual machine and immediately run demo, website, or web service in a virtual environment.
3) Server installation - step-by-step instructions for installing on a Windows or Linux machine/server.
Autotune has been used in 3 countries, integrated into 5 companies' energy modeling pipelines, and being considered for application by 4 U.S. government agencies. Autotune does use OpenStudio (slide 32) for initial model creation, but only EnergyPlus during calibration for the reasons of speed and scalability. While created to be simulation-engine agnostic for easy application with new versions or simulation engines, the primary limitation for most users is that the open-source version uses EnergyPlus 7.0. Ultimately, it is up to the user to determine whether Autotune, OpenStudio, or other private-sector calibration services work best for your needs.
