Often times removing and replacing an entire HVAC system is quite difficult to get right only using measures. I would do a "save as" and then edit the HVAC systems using the apply measures now capability in OS and then manually edit whatever is necessary to get the systems exactly how you want them. You can then import these models into PAT to run everything at once if you want to.
