The most direct fix to your line of code is:
subprocess.call(['C:\EnergyPlusV8-5-0\energyplus.exe', '-w', 'path/to/weather.epw', 'PackagedTerminalHeatPump.idf'])
The EnergyPlus executable always comes first in the list of arguments passed to subprocess.call (or check_call or Popen), and the IDF comes last. For the other options, you specify the option, then its argument (where required).
Here is the CLI help which you may find useful in building up your command.
EnergyPlus, Version 8.5.0-c87e61b44b
Usage: energyplus [options] [input-file]
Options:
-a, --annual Force annual simulation
-d, --output-directory ARG Output directory path (default: current
directory)
-D, --design-day Force design-day-only simulation
-h, --help Display help information
-i, --idd ARG Input data dictionary path (default: Energy+.idd
in executable directory)
-m, --epmacro Run EPMacro prior to simulation
-p, --output-prefix ARG Prefix for output file names (default: eplus)
-r, --readvars Run ReadVarsESO after simulation
-s, --output-suffix ARG Suffix style for output file names (default: L)
L: Legacy (e.g., eplustbl.csv)
C: Capital (e.g., eplusTable.csv)
D: Dash (e.g., eplus-table.csv)
-v, --version Display version information
-w, --weather ARG Weather file path (default: in.epw in current
directory)
-x, --expandobjects Run ExpandObjects prior to simulation
Example: energyplus -w weather.epw -r input.idf
I've wrapped this up in a little module you can find here. So long as EnergyPlus is installed in the usual place for your system and the install directory is on your path then this ought to work straight out of the box.
