Since subprocess.check_call shouldn't have stdout and stderr piped, you should use Popeninstead.
import subprocess
eplus_path = '/Applications/EnergyPlus-8-6-0/energyplus' eplus_file = '5ZoneAirCooled.idf' weather_file = 'USA_CO_Golden-NREL.724666_TMY3.epw'
df = subprocess.Popen([eplus_path, "-w", weather_file, eplus_file], stdout=subprocess.PIPE)
output, err = df.communicate()
print(output.decode('utf-8'))
if not err is None:
print(err.decode('utf-8'))
Since subprocess.check_call shouldn't have stdout and stderr piped, pipes, you should use Popeninstead.instead (see subprocess documentation)
import In a case where it goes well, I'll see something that starts with:
EnergyPlus Starting
EnergyPlus, Version 8.6.0-198c6a3cff, YMD=2017.01.17 23:46
Processing Data Dictionary
Processing Input File
... etc
In a case where for example I don't have the right idf file in my folder:
ERROR: Could not find input data file: /Users/julien/Software/RunningEPlusFromPython/2ZoneAirCooled.idf.
Type 'energyplus --help' for usage.
Since subprocess.check_call shouldn't have stdout and stderr pipes, you should use Popeninstead (see instead.
See the subprocess documentation especially subprocess documentationcheck_call) and for Popen.
import subprocess
if not err is None:
EnergyPlus Starting
... etc
| 4 | No.4 Revision |
Since subprocess.check_call shouldn't have stdout and stderr pipes, you should use Popeninstead.
See the subprocess documentation especially check_call and for Popen.
import subprocess
if not err is None:
EnergyPlus Starting
... etc
Note that the subprocess calls expects a list of arguments. Using shlex to decompose a command line (that you can try directly in a terminal/cmd prompt) can be useful:
In [1]:
import shlex
command_line = '{eplus_path} -w {weather_file} {eplus_file}'.format(eplus_path= eplus_path, weather_file=weather_file, eplus_file=eplus_file)
print(command_line)
Out [1]:
/Applications/EnergyPlus-8-6-0/energyplus -w USA_CO_Golden-NREL.724666_TMY3.epw 5ZoneAirCooled.idf
In [2]: shlex.split(command_line)
Out[2]: ['/Applications/EnergyPlus-8-6-0/energyplus',
'-w',
'USA_CO_Golden-NREL.724666_TMY3.epw',
'5ZoneAirCooled.idf']
| 5 | No.5 Revision |
import subprocess
if not err is None:
EnergyPlus Starting
... etc
In [1]:
import shlex
print(command_line)
Out [1]:
'-w',
If you need to do this, here's how:
import subprocess
# If python 2.7: `from __future__ import print_function`
popen = subprocess.Popen([eplus_path, "-w", weather_file, eplus_file],
stdout=subprocess.PIPE, universal_newlines=True)
# Might need to use `#for stdout_line in iter(popen.stdout.readline, ""):` instead in python 2.7
for stdout_line in popen.stdout:
print(stdout_line)
popen.stdout.close()
return_code = popen.wait()
if return_code:
raise subprocess.CalledProcessError(return_code, popen.args)
| 6 | No.6 Revision |
import subprocess
if not err is None:
EnergyPlus Starting
... etc
In [1]:
import shlex
print(command_line)
Out [1]:
'-w',
import subprocess
print(stdout_line)
if return_code:
From the docs on the energyplus CLI (command line interface), if you don't supply -w weather_file_path it searches for in.epw in the current directory (where it's called from). So a quick fix would be to make sure that your weather file is there an named in.epw. Just saying.
