1 | initial version |
There is a noticeable time increase.
Program Version,EnergyPlus, Version 8.5.0-c87e61b44b, YMD=2017.01.12 15:11,IDD_Version 8.5.0
************* EnergyPlus Completed Successfully-- 626 Warning; 486 Severe Errors; Elapsed Time=00hr 08min 45.14sec
The V8.6 file has been running for 20 minutes and is just starting Feb. I suspect that a code correction or update has added considerable runtime. I also assume this file will be used to benchmark function timing to track down the culprit.
