Like Eric said, ZoneHVACUnitHeater does have a remove method. To illustrate, just open an irb (or pry session).
First, let's create a model with a ZoneHVACUnitHeater:
model = OpenStudio::Model::Model.new
fan = OpenStudio::Model::FanConstantVolume.new(model, model.alwaysOnDiscreteSchedule)
hc = OpenStudio::Model::CoilHeatingWater.new(model)
uh = OpenStudio::Model::ZoneHVACUnitHeater.new(model, model.alwaysOnDiscreteSchedule, fan, hc)
Now, you can quickly check what methods are available by using object.methods. You can chain grep to match a regex pattern, here a simple one that's case insensitive using the i modifier:
uh.methods.grep(/remov/i)
=> [:removeFromThermalZone,
:isRemovable,
:remove,
:removeLifeCycleCosts,
:remove_instance_variable]
You can remove it, and observe that it also deletes the coils etc.
[1] (main)> model.getZoneHVACUnitHeaters.size
=> 1
[2] (main)> model.getCoilHeatingWaters.size
=> 1
[3] (main)> uh.remove
=> [#<OpenStudio::IdfObject:0x007f990e925de8
@__swigtype__="_p_openstudio__IdfObject">,
#<OpenStudio::IdfObject:0x007f990e925d98
#<OpenStudio::IdfObject:0x007f990e925d48
@__swigtype__="_p_openstudio__IdfObject">]
[4] (main)> model.getZoneHVACUnitHeaters.size
=> 0
[5] (main)> model.getCoilHeatingWaters.size
=> 0
Like Eric said, ZoneHVACUnitHeater ZoneHVACUnitHeater does have a remove method. To illustrate, just open an irb (or pry session).
:isRemovable,
:remove,
=> 1
=> 1
=> 0
=> 0
