If you are using AWS then update your OS Server Version to '1.21.4' in the spreadsheet. This uses OS version 1.13.2. If you are building your own Vagrant Boxes, then do a pull from Develop branch of OS Server and rebuild.
The Gemfile's in the Server have been version locked to the 1.6.8 Nokogiri gem.
I believe this is going to impact all older AMIs as well.
