You could create a custom copy of the Report that had more columns, but to create this table the measure already requests hourly zone temperatures for all zones for the entire run period. You could open ResultsViewer and view a heat map for specific zones you want to inspect.
If you wanted the flood map in a reporting measure, you could adapt the [Meter Flood Plot] measure(https://bcl.nrel.gov/node/39419) to plot any variable.
Probably not what you want, but I thought I'd mention the View Data measure puts time series surface or zone variables on 3d geometry that you can animate over the year.
