That appears to be to just be a display error on the argument units by the measure writer. Looking through the measure.rb it does appear that the "window_height" argument is used as a length in meters as shown below.
#loop through exterior zones adding ZoneVentilationWindStackOpenArea object
used_exterior_zone_names.sort.uniq.each do |used_exterior_zone|
#IDF object text for ZoneVentilationWindStackOpenArea
string_objects << "
ZoneVentilation:WindandStackOpenArea,
#{used_exterior_zone}_WindStack, !- Name
#{used_exterior_zone}, !- Zone Name
#{open_area}, !- Opening Area {m2}
Always On Discrete 1 WindStack, !- Opening Area Fraction Schedule Name
autocalculate, !- Opening Effectiveness {dimensionless}
0, !- Effective Angle {deg}
#{window_height}, !- Height Difference {m}
autocalculate, !- Discharge Coefficient for Opening
#{min_indoor_temp}, !- Minimum Indoor Temperature {C}
, !- Minimum Indoor Temperature Schedule Name
#{max_indoor_temp}, !- Maximum Indoor Temperature {C}
, !- Maximum Indoor Temperature Schedule Name
#{delta_temp}, !- Delta Temperature {deltaC}
, !- Delta Temperature Schedule Name
#{min_outdoor_temp}, !- Minimum Outdoor Temperature {C}
, !- Minimum Outdoor Temperature Schedule Name
#{max_outdoor_temp}, !- Maximum Outdoor Temperature {C}
, !- Maximum Outdoor Temperature Schedule Name
#{max_wind_speed}; !- Maximum Wind Speed {m/s}
end
You can comment on the measure on BCL, but I don't think authors get any notifications about comments, so we can contact them, since as a BCL moderator we have their contact info.
