Thermal bridges can be introduced in OpenStudio or Energy plus using small sub-surface with the same thermal transmission than the thermal bridge. You need to calculate the thermal bridge using other tool (ie Therm), and then you can use one construction with a no mass material in order to introduce the thermal transmission due to thermal bridge.
