Here is a Replace Default Construction Set measure written by another UnmetHours user. You an can adapt a few lines on that measure to operate on "DefaultScheduleSet" instead of "DefaultConstructionSet" to make a measure that sets an existing DefaultScheduleSet to the building.
Keep in ind if any spaces in your model have space types assigned that have their own DefaultSchduleSets, those would overwrite the building level defaults. Do you really want the same schedule set across the building vs. having activity assigned by space type?
For reference, here is link to DefaultScheduleSet API documentation.
