I have much the same issue. INstalled 2017, found that didnt work, so un-installed everything. INstalled 2016, then openstudio 1.13. And when starting sketch-up I have a bunch of errors . I also have installed both apps to the same folder.
Errors below:
Error Loading File C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio/Startup.rb
Error: #<runtimeerror: unable="" to="" initialize="" openssl:="" verify="" that="" ruby="" can="" access="" the="" openssl="" libraries="">
D:/CymapDev/IFC/OpenStudio/OpenStudio 1.13.0/Ruby/openstudio.rb:153:in <top (required)>'
D:/CymapDev/IFC/OpenStudio/OpenStudio 1.13.0/sketchup/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:inrequire'
D:/CymapDev/IFC/OpenStudio/OpenStudio 1.13.0/sketchup/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio/OpenStudio-config:2:in<top (required)>'="" c:="" programdata="" sketchup="" sketchup="" 2016="" sketchup="" plugins="" openstudio="" startup.rb:33:in="" <code="">load'
C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio/Startup.rb:33:in<top (required)>'="" d:="" cymapdev="" ifc="" openstudio="" openstudio="" 1.13.0="" sketchup="" tools="" extensions.rb:197:in="" <code="">require'
D:/CymapDev/IFC/OpenStudio/OpenStudio 1.13.0/sketchup/Tools/extensions.rb:197:inload'
C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio.rb:176:in register_extension'
C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio.rb:176:in<top (required)>'<="" p="">
