Blow program can read mutiple results:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Runtime.InteropServices;
namespace ConsoleApplication1
[StructLayout(LayoutKind.Sequential,Pack=4)]
public struct MultResultsType
public int iEntryID; // from NHRList.txt
public int iReturnValue; // success/failure
[MarshalAs(UnmanagedType.ByValTStr,SizeConst =40)]
public string pszReportKey;
[MarshalAs(UnmanagedType.ByValTStr,SizeConst = 40)]
public string pszRowKey;
class Program
[DllImport("kernel32.dll")]
public extern static IntPtr LoadLibrary(string dllToLoad);
[DllImport("kernel32.dll", EntryPoint = "GetProcAddress")]
public extern static IntPtr GetProcAddress(IntPtr hModule, string procedureName);
[DllImport("kernel32.dll", EntryPoint = "FreeLibrary")]
public extern static bool FreeLibrary(IntPtr hModule);
[UnmanagedFunctionPointer(CallingConvention.Cdecl)]
private delegate long D2R_GetSingleResult([MarshalAs(UnmanagedType.LPStr)]string pszDOE2Dir,
[MarshalAs(UnmanagedType.LPStr)]string pszFileName,
int iEntryID,
float[] pfData,
int iMaxValues,
[MarshalAs(UnmanagedType.LPStr)]string pszReportKey,
[MarshalAs(UnmanagedType.LPStr)]string pszRowKey);
private delegate long D2R_GetMultipleResult([MarshalAs(UnmanagedType.LPStr)]string pszDOE2Dir,
int iFileType,
//[MarshalAs(UnmanagedType.LPArray)]
float[] pfData,
int iMaxValues,
int iNumMRTs,
[In,Out]IntPtr pMRTs);
unsafe public static IntPtr MarshalArray(ref MultResultsType[] bodies)
int iSizeOfOneBodyPos = Marshal.SizeOf(typeof(MultResultsType));
int iTotalSize = iSizeOfOneBodyPos * bodies.Length;
IntPtr pUnmanagedBodies = Marshal.AllocHGlobal(iTotalSize);
byte* pbyUnmanagedBodies = (byte*)(pUnmanagedBodies.ToPointer());
for (int i = 0; i < bodies.Length; i++, pbyUnmanagedBodies += (iSizeOfOneBodyPos))
IntPtr pOneBodyPos = new IntPtr(pbyUnmanagedBodies);
Marshal.StructureToPtr(bodies[i], pOneBodyPos, false);
return pUnmanagedBodies;
static void Main(string[] args)
// Dynamically Load Library
var pDll = LoadLibrary("D2Result.dll"); // Path to D2Result.dll
// Get Address of Function
var pFunctionAddress = GetProcAddress(pDll, "D2R_GetMultipleResult");
// Instantiate Delegate
D2R_GetMultipleResult D2R_GetMultipleResult = (D2R_GetMultipleResult)Marshal.GetDelegateForFunctionPointer(pFunctionAddress, typeof(D2R_GetMultipleResult));
string pszDOE2Dir = "doe22\\exent.ref\\"; // Insert path to DOE-2 Dir i.e "C:\\DOE-2\\
string pszFileName = "Project 10\\Project 10 - Baseline Design"; // Insert file path of where the input and run files are kept
float[] pfData = new float[1] ;
//string pszReportKey = null;
//string pszRowKey = null;
MultResultsType[] MRTs=new MultResultsType[4];
MRTs[0].iEntryID = 2309007; // EM1 array from PS-F
MRTs[0].pszReportKey = "EM1";
MRTs[0].pszRowKey = "";
MRTs[1].iEntryID = 2309007; // FM1 array from PS-F
MRTs[1].pszReportKey = "FM1";
MRTs[1].pszRowKey = "";
MRTs[2].iEntryID = 2305005; // Elec Mtr Totals from PS-E
MRTs[2].pszReportKey = "";
MRTs[2].pszRowKey = "";
IntPtr pt = MarshalArray(ref MRTs);
float[] fResults=new float[39];
long lRetVal = D2R_GetMultipleResult(
pszDOE2Dir,
pszFileName,
1, fResults, 39, 3, pt);
for (int i = 0; i < 39;i++ )
Console.WriteLine("pfData is {0}", fResults[i]);
bool freedom = FreeLibrary(pDll);
Console.ReadKey();
