|   | 1 |  initial version  |
if illegal character contains in your sim file will also result in this problem,which is I always run into.For example,when I named my project name or component name in chinese,the sim file will corrupt when I open it using SIM explorer.And I revised the peoject name or component name into English,the sim file can be open successfully.
|   | 2 |  Suggested edit  |
if illegal character contains in your sim file will also result in this problem,which is I always run into.For example,when I named my project name or component name in chinese,the sim file will corrupt when I open it using SIM explorer.And I revised the peoject name or component name into English,the sim file can be open opened successfully.
|   | 3 |  Suggested edit  |
if illegal character contains in your sim file will also result in this problem,which is problem.For example,if I always run into.For example,when I named named my project name or component name in chinese,the sim file will corrupt when I open it using SIM explorer.And I revised the peoject name or component name into English,the sim file can be opened successfully.
