If you move the OSM without also moving the accompanying directory of the same name, you won't only loose the measures in the workflow, you will also lose the weather file. You can choose SaveAs from the application and it will manage this for you. Or if you have to send someone your project, ideally zip up 'MyModel.osm' and the 'MyModel" directory.
