I recommend the Room Air Models in EnergyPlus which aimed modeling non-uniform room air temperatures that may occur within the interior air volume of a zone. The Room Air Models contained different air distribution models, for example ThreeNodeDisplacementVentilation used to simulate displacement ventilation. If you had conducted a CFD analysis, define your air model using RoomAir:TemperaturePattern:UserDefined. Refer to Input Output Reference for more information and UserDefinedRoomAirPatterns.idf in ExampleFiles may help you have a better understand of this model.
