I think you may divide the indoor zone into two zones, divided in the middle by two walls. 1) the thick wall, 2) An air wall.
I think you may could divide the indoor zone into two zones, divided in the middle by two walls. 1) the thick wall, 2) An air wall.
I think you could divide the indoor zone into two zones, divided in the middle by two walls. 1) the The thick wall, 2) An air wall.
| 4 | No.4 Revision |
I think you could divide split the indoor zone into two zones, divided in the middle by two walls. 1) The thick wall, 2) An air wall.
