As far as I know you cannot report these variables directly, and it makes perfect sense why: the demand charges concern the monthly peak, so reporting these every hour doesn't make much sense, the reporting has to be monthly and can therefore be tabulated easily and that's why it ends up in the eplusout.html.
If you still want to go ahead, I would just report the Electricity:Facility meter at the hourly timestep and post-process that. I've done that several times to analyze via post-processing different time of use tariffs. It's not terribly complicated.
