at a minimum the thermal zone should have one or more spaces, those spaced should have surfaces, and.the surfaces need constructions. Lastly you need an epw file.
For specific information on why your simulation is failing look at OpenStudio troubleshooting documentation.
![]() | 2 | No.2 Revision |
at At a minimum the thermal zone should have one or more spaces, those spaced should have surfaces, and.the surfaces need constructions. Lastly you need an epw file.
![]() | 3 | No.3 Revision |
At a minimum the thermal zone should have one or more spaces, those spaced should have surfaces, and.the and the surfaces need constructions. Lastly you need an epw file.
