As an idea, did you put the correct schedule on your fans. For example, are they always on or did you put a schedule so they are off at night? The night cycle manager needs them to be off so it can turn them on if needed. You will need to put the availability manager on the fan coil object (if you open the .expidf file you will see that object expanded out from the templates. If you want the night cycle manager on the DOAS system you will need to put the availability manager on the airloopHVAC piece.
