Interesting. The example file 5ZoneDDCycleonAny also has no control zone input (last entry not entered)
AvailabilityManager:NightCycle,
VAV Sys 1 Avail, !- Name
SysAvailApplicSch, !- Applicability Schedule Name
FanAvailSched, !- Fan Schedule Name
CycleOnAny, !- Control Type
1, !- Thermostat Tolerance {deltaC}
7200.; !- Cycling Run Time {s}
The IDD calls for these inputs. Note that this object states only 6 inputs are required, not 7. Try entering the name of the zone you want to use to test zone conditions for when the AHU should turn on.
\min-fields 6
A1 , \field Name
A2 , \field Applicability Schedule Name
A3 , \field Fan Schedule Name
A4 , \field Control Type
N1 , \field Thermostat Tolerance
N2 , \field Cycling Run Time
A5 ; \field Control Zone Name
