I would expect one of two scenarios.
1) The windows are overlapping on the first floor.
2) The windows were not copied into an OpenStudio Space. For walls and windows to save in the OpenStudio file they much be within a space. I would double check that the windows and walls are each in a space. Either add your surfaces and windows to spaces or double click into the space (black + sign) to check if windows appear/disappear.
I have seen walls and windows disappear after closing and reopening a file because of the above reasons or an error that causes the program to delete them automatically because they're not valid. Try managing your spaces and see if you can correct this problem.
2) The windows were not copied into an OpenStudio Space. For walls and windows to save in the OpenStudio file they much must be within a space. I would double check that the windows and walls are each in a space. Either add your surfaces and windows to spaces or double click into the space (black + sign) to check if windows appear/disappear.
2) The windows were not copied into an OpenStudio Space. For walls and windows to save in the OpenStudio file they must be within a space. I would double check that the windows and walls are each in a space. Either add your surfaces and windows to spaces or double click into the space (black + "+" sign) to check if windows appear/disappear.
