See the answer to these questions:
Many variables are available by toggling them in the Output Variable tab in OpenStudio. E.g., for Zone Air Temperature:
If there is a variable that is not available in this tab, you can add it with the "Add Output Variable" measure, described in the answers to the questions above.
There are several ways to export output variables to .csv format. See the answers to the previous questions.
