Thank you, with problems comes the answers necessity, i appreciate the time everybody took to help me.
I create the model, similar and is evident the reduction in cooling compressors energy consumption, but the only item i don´t understand is How the freecooling loop work when the outdoor condition is not sufficient to use indirect freecooling and the effect is reverse, to heat the air in place of to cool the air.
In other words, how do i tell the program to deactivate the freecooling loop when the water is above 60°F?
with this "Heat Transfer Metering End Use Type = FreeCooling"
