Here's what I'd do: (link to the test model)
Create an AirLoopHVAC to serve the Data Center Zone with:
Create a PlantLoop to act as the heat rejection loop with:
Create a PlantLoop to act as the free cooling loop with:
Here is the cooling rate before adding the chilled water coil and free cooling loop:
Here is the cooling rate after. Notice that the chilled water coil (blue) is picking up part of the load, and the heat pump coil (orange) is picking up the rest of the load.
EDIT Yes, the water-to-air HP is actually doing less cooling in the second picture, it's just hard to see since the scales and screenshots aren't identical. Here's a before (green) and after (pink) of the HP coils plotted on the same plot.
