I opened your input (idf) file and see no thermostat. The set point manager in your file is a SetpointManager:SingleZone:OneStageHeating which is not what I would think should be used as a control for the gas heating coil. In OS, do you have any other options for set point managers to choose from? I changed your file to include a thermostat and changed the set point manager to be SetpointManager:SingleZone:Heating and the zone is now controlling the temperature to 20C for heating. I suspect there is a method to include a thermostat into your OS file which is what I believe you need to correct.
