@CRHavis, thanks for the file link. I can re-produce what you are saying. I'll file an issue to fix this. Currently the measure works with hard assigned constructions, and construction sets inherited from the building level, but not construction sets inherited from the space, space type, or building story. I'll post updated measure online once I get it changed and tested, but for now either hard assign or only use a building level default construction set. You have it assigned at building level, space type, and space.
