To import Tess library into trnsys 16 ,performing following steps:
1.Decompress the Tess package and you can get three folders ,which are icon, proformas and Tess models.
2.Copy the files located in Tess models/Dlls/debug version and Tess models/Dlls/Release version into userlib folder located in trnsys installation directory.If Debug version folder and Release version folder exist in userlib,just combine the both folder with Tess models/Dlls/debug version and Tess models/Dlls/Release version respectively.
3.Copy the Tess models folder into Trnsys installation root directory.
![]() | 2 | No.2 Revision |
To import Tess library into trnsys 16 ,performing 16, performing following steps:
1.Decompress Decompress the Tess package and you can get three folders ,which are icon, proformas and Tess models.
2.Copy Copy the files located in Tess models/Dlls/debug version and Tess models/Dlls/Release version into userlib folder located in trnsys installation directory.If directory. If Debug version folder and Release version folder exist in userlib,just userlib, just combine the both folder with Tess models/Dlls/debug version and Tess models/Dlls/Release version respectively.
3.Copy Copy the Tess models folder into Trnsys installation root directory.
